The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Replaced digitizer, ipad 2 wifi does not work well
I tried to replace by digitizer for my ipad 2 wifi. It went on almost fine. On connecting the digitizer, the wifi is having issues. Weak signal. Says wrong password and works only when close to the router.
Please check the image. I must have broken this cable. Note that the wire is still attached but a small strand only.
Can you please tell me what this wire is about ?
Thank you for reading this.
Score -1
2 Comments
Thanks Brian. Is this totally broken ? Can I not get away without replacing it ?
by
No, if want your wifi back,you'll need to replace it.
by
Add a comment
1 Answer
Chosen Solution
That is the wifi antenna, replace that and you should be fine.
Score 2
Add a comment
Add your answer
Observer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 124
