Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Questions View all
Could I replace the internal HDD with something much larger?
I run Windows and OS X on my iMac, and I've had it upgraded to the "3TB Fusion Drive".
If I was to replace the HDD with, say, a 6TB drive (Say, something like this http://www.ebay.com.au/itm/Western-Digit... ) would everything still work okay?
From my understanding, Fusion Drive is flash storage and a HDD working together so that the things that need priority go on flash, and remainder on HDD. Will I still have this functionality?
Is the HDD even a 3.5"? It appears to be in the images I've seen.
Thanks in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
First I should warn you the newer 'Thin series' iMacs are a bear to open! We've had a few people here kill their displays in the process (review some of the Q's posted here) which is an expensive oops! You will need the correct tools and you really need to follow the guide to the letter as its real easy to kill the display (I've killed one!) And we thought we knew what to do (to be fair it was before the guide was completed).
The second point here is the system is designed to run with minimum amount of fan noise. So when you alter the internals with a hotter running drive you'll start to have more fan noise as the system combats the added heat.
As these larger drives are so new I would hold off a bit. You also may find you really don't need that much internal storage. External RAID drives can offer equal if not faster response.
OK, so you still want to do this! Follow the IFIXIT guide here: iMac Intel 27" Retina 5K Display Hard Drive Replacement. You'll also need this cable: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as the drive you are putting in likely doesn't have the required signaling for the SMC services to monitor the drives temp to scale up the fan and besides having a second set of tapes will be helpful.
As to the doing this you'll need to make a backup of your data. You'll need to break the Fusion drive set so the two drives are seen discreetly on the desktop. Only then can you take the drive out.
I do recommend you prep up the drive externally beforehand. You only need to format it using Disk Utility so its GUID. You'll need access to the internet for the system to go into internet recovery.
Score 1
1 Comment:
And Yes, the drive is a 3.5" drive. Make sure you don't get one thats too high in height.
by
Add a comment
Add your answer
Timikan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 191
