Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
89 Questions View all
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
Score 5
2 Comments
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
by
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
by
Add a comment
1 Answer
Chosen Solution
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Score 4
3 Comments:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
by
That site appears to have been hijacked.
by
Add a comment
Add your answer
mvmarroquin will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 25
All Time: 18,582
