BlackBerry's newest flagship that features a physical keyboard.
73 Questions View all
Can blackberry passport water damage be fixed?
My blackberry passport fell inside water. i picked it and dried it and it worked for about a week till it suddenly went off and won't power up again.
I've taken it to the repair and i'm told i need to change the panel which is unavailable in the Nigerian market. please where can i get the panel. also will it be possible to fix this phone
Score 1
Add a comment
No change for main board needed ask technician to remove ( brake ) one rectangular resistor between battery connector and display connector. If phone have water inside this resistor change and drain battery to 0 and prevent charge. I do same on may Passport and it working after one minute charging.
Add a comment
yes its possible the phone will work, what ill like you to do is to contact me or watsap me on 08030732622,you be happy you did
1 Comment:
hi chucks kindly sendme a watsap message on my contact,im based in Abuja we will discuss how in get the phone for repair
by
Add a comment
Add your answer
chukseboagwu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,823
