Harley-Davidson Sportster Motorcycles from 1986 to Present.
34 Questions View all
How do I change my starter?
how can i change my starter for a 07' sportster
1 Comment:
How to change a starter on a 1999 sportster
by
Add a comment
It won't be fun.
1. remove battery
2. remove primary cover (leftfoot peg probably needs to come off to do this)
3. remove rear exhaust pipe
4. remove (you might get away with just loosening this) the drivebelt front sprocket cover (right footpeg and front muffler might interfere)
5. remove starter wiring
6. remove starter bolts
7. remove starter
reverse procedure to install
In addition to the starter itself, you'll want to have gaskets for the following:
- rear exhaust port
- exhaust crossover tube
- primary cover set
and oil to refill the primary chain case
Add a comment
How do you change starter in 86 harley sportster 883
2 Comments:
I think that is first year evo, so it should be similar to above.
by
Ok thanks it's alot of work to remove the starter
by
Add a comment
Add your answer
Israel Sandoval will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 61
All Time: 7,505
