Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Difference between ipad mini lcd and ipad mini 2 lcd
Hi, I have a bunch of iPad mini LCD's and I'm curious if there are any physical differences (not talking about resolution here) between ipad mini and mini 2 LCD's? I have a lot to go through so any difference that I can quickly glance at would be very helpful.
Thanks.
Score 3
Add a comment
Chosen Solution
I've found a difference.
If you're looking at the LCD from the back there is a small cable on the right.
On the Retina displays the cable comes up from the bottom of the display.
On the non-retina displays the cable comes from the side of the panel.
Score 2
1 Comment:
Would like a photo if possible
by
Add a comment
You know, I'm pretty sure you're right. But while looking for both images to show side by side, Google shows both the ribbons the same. I did notice the strip across the bottom missing from the mini1. Tho I can currently only vouch for the mini2 in front of me.
-Both of these images are from a Google search result. I am not the photographer. All credit goes to them, and all that jazz.
Add a comment
Add your answer
RegencyTech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,612
