Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone damaged LCD screen
Helo,
I was cleaning my iphone with alcohol, then i found that alcohol had entered to my screen (i think between the glass and the screen). I turned my phone off and after 12 hours i turned it on again, I found that there is a little small drop remaining! Please can you help me to remove them?
Best Regard.
Add a comment
1 Answer
you can try to heat the screen up a little bit to evaporate the alcohol but not too much as you might damage the lcd. Alcohol evaporates at 78 degrees celcias which is not enough to damage the lcd.
Add a comment
Add your answer
alimadi639 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 311
