Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
Charge port, home button, and headphone jack not working
I replaced the plastic back casing of the iphone 5c with a new one. I have plenty experience working with these phones and something has happened that i haven't run into before. Everything went back together fine in the new case. Turned it on and the home button will not work along with the charging port not recognizing the charging cable. All the while the phone is stuck in headphones mode. I am not sure if the mic works or not but i'm thinking it might be the cable that works all of these functions. Have you guys ever ran into a problem like this? If so what do you suggest I do? Thank you in advance.
Devin
Add a comment
1 Answer
Most Helpful Answer
Just replace the whole charging port/mic/home button/speaker assembly. As you may have noticed, these are all lumped into 1 component, so replacing it would most likely fix all your problems. hth.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 637
