laptop will not turn on (power up or boot)
Hello all and thanks in advance for any assistance!
Recently given the aforementioned laptop by my cousin whose daughter allegedly accidentally spilled water on same.
Tore entire machine apart, no signs of water or any "blue" indicator pads.
Symptoms: power cord/adapter works fine on another MacBook Air,Mag Safe connector shows orange while charging, then goes to green. When same adapter cord is used on the non-starting MacBookPro, MagSafe connector light does not go on or is very very dim almost non existent. However, if you first put connector onto known good computer then onto the non-starting one, the green light comes on brightly which goes immediately to orange as one would expect as if charging the battery.
Is this a symptom of a possibly bad MagSafe board ? When I check the voltage of the MagSafe board while connected to AC power I get 17.21 volts DC from any combination of the four pads on the MagSafe board.
I am a competent tech on PC's but this is my first MAC experience and I'm having a tough time with this one.
Would you first try a new MagSafe board,and if that does not work and machine still does not turn on then replace keyboard with its connected ON-OFF switch, and lastly replace the Logic Board if machine still does not power up? Any help would be greatly appreciated!!!
Thanks!
1 Comment
Thanks for accepting my answer, please tell us what fixed it. Thanks
by mayer
