Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3189 Questions View all
iPhone 5 Shows Charging - But isn't
Hello GREAT community of iFixit! First off I have to say hats off to all you fellas.
Now to my problem. My friend asked me to fix his iPhone 5 which has a really strange problem(s):
  • The device randomly reboots
  • Sometimes screen turns blue and reboots
  • Says charging but percentage doesn't pick up. (sometimes)
To give a bit of background, the device fell, which made the screen bulge out at the bottom, and after time the glass separated from the LCD resulting in massive screen bleeds. This is when it all started. I replaced the screen, and because I did this I unplugged the battery which solved the problems temporarily. Some additional info: The volume down button also doesn't work but V+ and Mute is fine.
When I remove the battery and hold the power button for a while, the phone works normally again for around two days. Btw. When I remove the battery and plug in the charger the Apple logo appears.
What I've tried:
  • Resetting the device
  • Different Cables
  • Cleaning all the ports
I'm not sure if I should replace the battery or the lightning connector? What's your thoughts?
Add a comment
1 Answer
Most Helpful Answer
The short answer on how I'd do it: get both and test simultaneously. Although I have a feeling it is the battery, or neither.. since you mentioned a blue screen.
Here's the long answer: how I'd do it if I received this in my shop for repair.
First, since you mentioned a bad drop and a previous repair (by you), I would examine the logic board using good magnification. This is to detect drop damage and pry damage and try to rule them out, at least partially or the most obvious.
There are parts covered by metal shields, and parts that are not.
Those parts that are not covered contain important components that if damaged, may make your iPhone behave strangely.
So I'd start by looking next to the battery connector, next to the SIM tray (there is a glass IC/component near that area that if chipped will render your iPhone completely useless!!! So be very careful removing the interconnect cables that cover that chip), and around the screen connectors on top (I'd very carefully remove the "thin black foil" covering that area, since prying to remove it may pop tiny components off).
If I find something damaged, broken off, or completely missing, I replace it using micro soldering tools and a very steady hand. If you miss the prerequisites, post a god quality picture here and we'll tell you if it is a critical component and what to do next.
Second, I would test the phone using only a known good battery, lightning connector (you can overlay and connect those 2 while the logic board is still in it's case), and known good screen of course. Don't forget to disconnect the PMV (Power-Mute-Volume cable).
Once the setup is ready, connect the iPhone to your laptop. The iPhone should start (because the PMV cable is disconnected), charge, and get recognized by iTunes.
Let us know if something does not work as described.
However, if all is well, connect back the original lightning connector, then battery, to see if any of them brings about any bad behavior. Then the PMV.
Good luck.
Score 2
Thank you very much for your detailed answer. The problems were there before I started work on it, I doubt it was a prying issue. I did inspect the main board with a magnifying glass and that too looked okay. I've ordered a new battery, will test with that. I'll keep you posted.
I'm just worried about the blue screen. Any of the LCI's been triggered?
Add a comment
Add your answer
Giovanni Joubert will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 28
All Time: 3,229
