Eighth generation of the Mazda Protege.
Question Closed
I have an error code P0300.
when a press on the gas sometimes it does not speed up as supposed, on the contrary it perform as it is something obstructing the gas injection, the engine shakes and moves forward very slowly, after few metters it goes back to normal. Any idea??
2 Comments
I have this problem now for months change coil pack spark plugs o2 sensors fuel pressure regulator and EGR Value same problems engine shakes and moves slow
by
keep getting code PO 300
by
Add a comment
1 Answer
Chosen Solution
Ali Hosman Rivero , DTC P0300: RANDOM MISFIRE DETECTED
Possible causes are: Camshaft Position (CMP) sensor malfunction.
Crankshaft Postion (CKP) sensor malfunction.
EGR system malfunction.
Excessive air leak in intake-air system between Mass Airflow (MAF) sensor and dynamic chamber.
Fuel line leak.
Fuel pressure regulator malfunction.
Fuel pump malfunction.
Ignition coil malfunction.
MAF sensor malfunction.
PCV valve malfunction.
Plugged or restricted fuel filter.
Plugged or restricted fuel line.
Poor connection or wiring problems.
Poor fuel quality.
Purge solenoid valve malfunction.
Secondary ignition system malfunction.
Vacuum hoses damaged or improperly connected.
Most common cause is that the coil packs are starting to go, they only mis-fire the engine cylinders sometimes.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,316
