Front camera not working. Pry damage
So recently I've discovered that my front camera isn't working due to pry damage. Apparently I've damaged/knocked off a tiny component below the third 'slot';. Thus, the soldering solution, to create a jumper, doesn't work as the 'two pins' are missing.
Is there any solution? Can I buy the tiny component?
I'm not an engineering so I hope you can keep your answer concise. Thank you.
