Glass cracked screen works fine can I replace the screen only?
I only wish to purchase the screen—not the digitizer. Do you know where can i buy genuine glass?
The glass is glued to the digitizer, so you need to replace the entire assembly at once.
There are some groups that will give you credit if you mail them your cracked assembly, but it's usually only a few dollars.
Marc Simpson, even if you can find the replacement glass, you still have to use an LCD separator to remove it from the LCD. Then you will need to re-adhere the new glass with OCA which by itself requires practice, patience and the right tools. The money you will save on the glass, instead of purchasing a complete assembly, will cost you way more after all that, with limited success. Apple will charge you $109 for the complete repair. Check on here. If you do want to fix it yourself, get the guide and part from here.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 196
1 Comment
Your questions sounds really easy, but it isnt.
by atimaier
