Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
spilled coke on keyboard, most keys dont work
I spilt coke on my keyboard but it actually not a lot but most of my keys dont work. my first reaction was to get a towel and rub the keys. then i turned it on and off my it still wont work. can i get this repaired? id so, how much ?
Add a comment
1 Answer
Most Helpful Answer
Not good ;-{
Coke and other soft drinks have sugars and acids that corrode. So its very important to clean it all out as quickly as possible.
You might be able to pop off the keycaps and then using cotton swabs (Q-Tips) moistened with distilled water (not tap water!) clean out what is left. Then using Isopropyl alcohol (85% or better) go over the areas again.
If you are lucky the Coke didn't penetrate deeper. If it did then this will be expensive as the upper case assembly will need to be replaced. Here is the IFIXIT guide to give you an idea how much work it will be MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 97
