Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 won't turn on.
Hi. I recently bought an iPhone 6 on eBay, but it won't turn on. After opening it I checked the battery voltage and it was dead. I purchased a new battery and replaced it, but when I try to power it on nothing happens. Both interior and exterior of the phone are mint condition, no signs of water damage (marks are white, no corrosion), no signs of unscrewing. I tried charging it for a while, or connecting it to iTunes, but it won't detect it. Any ideas of what it could be?
5 Comments
Might have missed a connection or didn't plug a connector in the whole way possibly? I would re-open the iPhone and recheck your connections.
by
Just checked, all connectors are plugged in! :(
by
Try holding down the wake/sleep button and home button down at the same time till you see the apple logo.
by
If that don't work try connecting it to iTunes and try that same process.
by
It's not recognised by iTunes, I had no luck..
by
Add a comment
1 Answer
Chosen Solution
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex (see this guide). Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good. Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair.
Score 2
Add a comment
Add your answer
iKatia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 690
