Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Touchscreen Replacement Acting Erratically
Hi,
I just replaced the touchscreen on an iPad Mini.
The repair was done with the utmost care, but once laying the digitizer back down flat on the chassis, the touchscreen starts to register jittery and random input.
Once the touchscreen is lifted off the chassis, the problem goes away. Seems to be only when the digitizer makes contact with the aluminum frame.
If any one has any information on why this is happening and any possible fixes I would be very great full.
Thanks!
Score 1
Add a comment
1 Answer
Hello Lee,
This problem is caused either from;
Defective Glass
or
The strip of "padding" on the lower side of the LCD not being removed. I do not understand why you have to remove this padding, but you do. It looks like 5-6 (I don't remember the number in my head really..) cushions on a strip of tape that is very easily removed. (I believe there is one strip on each side of the LCD)
Add a comment
Add your answer
lee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 144
