Broke antenna connector off of airport card
Hi
I recently renovated my MBP, and I accidentally snapped one of the airport antenna connectors right off of the board, pin and all. If you need a visual reference, see below.
I super-glued the connector back to the board, and everything seems to be working fine.
Should I buy a new airport card just be safe? Or just leave it since it seems to be working?
2 Comments
Superglue is no substitute for soldering.The difficulty will now be the removal of the connector. It may destroy your solder pads or traces. Have it repaired by someone how can do some micro soldering.
by oldturkey03
Very true! Superglue only makes things worse!
by Dan
