How will an int. converted to an ext. hard drive work?
I have a dead logic board on my old macbook pro a1226. I have access to a working used a1226 but it has a more updated OS than my old one. if i convert my old hard drive to an external hd will it run just like an internal hard drive with the older versions of the OS and applications on that external hard drive. Or would i have to trade out the internal hard drive with my old hard drive to be able to run the older versions of the OS and older applications?
I'd like to know it will work before spending money on a external hard drive enclosure.
4 Comments
If you give us both your old systems and new systems last three digits of there serial numbers we can double check if the systems HD's are compatible.
by Dan
Thank you so much for your response.
So, if I'm understanding correctly, if I use the old HD as an external HD, the files will use the OS and applications of the internal HD? And, if the files are not compatible, I would have to install the old HD internally to enable it to run it's own OS and applications?
I thought I located a used, same model, computer that I could use for either scenario. But, didn't realize that it still might be incompatible. Well, I'll cross my fingers til I get it. The last three of my old computer are X91. Do I need an exact match?
by sksloveridge
Well... Yes & no. Mounting your old systems HD in an external case allows you to access the files off of it. As to the applications if you alter the boot disk setting you can in fact boot up under your old drive so you then could use the apps as if it were your old system.
by Dan
The incompatibility issue is strickly related to the difference between your old system and your new one. We'll need the serial number of the new system to see if the HD's are swappable.
by Dan
