Microsoft's third-generation Xbox game console, released November 22, 2013.
Dropped Xbox and panel came off
My Xbox one was dropped and the panel came off after snapping the panel in place. I turned on my Xbox and now the front buttons don't work and the picture doesn't even fix the TV screen. Does anyone know what's wrong with it?
5 Comments
Which panel came off? Can you post some pics?
by
Did the very front panel come off?
by
I have the same problem except mine won't read discs now. Anyone know what's wrong?
by
The front panel has a ribbon cable. If the panel is removed too violently ( if it is dropped and it falls off for example) then the cable may break resulting in no power to the power button.
by
Same happened to mine Alex did you ever resolve the issue
by
Add a comment
Most Helpful Answer
Mine dropped two feet and the left panel came off slightly it turns on won't turn off doesn't get passed the one won't even connect to the tv
Score 1
Add a comment
I did the same thing and front panel came off I put back together but not working. I took the front panel back off and pushed the plastic where the ribbon cable plugs in and it switched on. I have purchased a new ribbon cable from eBay £4. Hopefully this will sort the problem.
Add a comment
have you tried changing your display settings? if you tried that and it doesn’t work then you need to replace the harddrive. As for the faceplate not working you will either need to replace the faceplate itself or the power card.
Add a comment
I just slammed my Xbox long story lol not even from gaming just picked it up during a argument and threw it on the floor, ribbon cable ripped when front panel flew off I plug it in and put panels on I can’t use front power button but when I turn it on w controller the power block lights up and I hear noises like it’s running but then it will stop and the blocks light will go from green back to red Im going to order a new one but does anyone know how I can rig it to work for now since it’s trying to power on?
1 Comment:
hd ok bhbd hddhdf
by
Add a comment
I was playing football in my room and the football hit my Xbox the it dropped to the floor and the front piece where u turn it on at came off and the top came off I put it back together but its not working and my mom not gonna get me a new one how do I repair it
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 5,557
