wet phone now has lines on display
Phone fell in water, now has only vertical lines on display screen. Is this iPhone 6Plus now toast?
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
The lines you see are caused by water within the display assembly. These may go away with time but realistically, this will require a replacement screen.
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road. Not every water-damaged phone is recoverable and depending on the kind of liquid (salty, dirty, filthy), sometimes the success rate is quite low. That said, IMHO, it's always worth a try otherwise we are just piling up the e-waste.
The water is inside the phone, on the logic board and under the shields, even under the IC's. The real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 33
All Time: 4,489
