Will battery from Early-2015 work in Mid-2014?
Hello,
I was just wondering if the batter from the Early-2015 MacBook Pro Retina 13" would fit the Mid-2014 model in order to extend its battery life?
Hello,
The amount of difference between the batteries is not worth the amount of work and cost - Save your money.
I should point out the real difference is how the newer system manage having more run time is the logic improvements needing less power not the slight battery improvement.
Hey Dan ! Is it the same connector though ? I need to troubleshoot an early 2015 battery. Can I safely plug a mid 2014 battery in an early 2015 logic board? Thanks a lot !!
They have very different P/N's:
MacBook Pro 13" Retina (2015) link to IFIXIT Battery
* Specs: A1582 - 11.42v 74.9Wh - 6559mAh
* Apple P/N's: 661-02361, 020-00009
MacBook Pro 13" Retina (2014) link to IFIXIT Battery
* Specs: A1493 / A1502 - 11.34v 71.8Wh - 6330mAh
* Apple P/N's: 661-8154, 020-8146, 020-8147, 6712-6700
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 760
