13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Display winking on and off?
Hi everyone.
I'm having a really annoying problem with my Macbook. This problem involves the LCD, that blinks if the lid is moved up or down.
To make it stop blinking I need to find a right angle of the lid or to press in the corners on the bottom right or left of the display.
Could it be the LVDS cable?
Score -1
1 Comment
Looks like the screen is broken... you might need to replace it. Not gonna be cheap though.
by
Add a comment
1 Answer
Chosen Solution
In most cases when moving the screen causes image glitches like this it is due to a faulty LVDS cable. However, the non-digital looking yellow fade in the corners would indicate an LCD failure.
Score 1
1 Comment:
The yellow faded corners are a mistake that I did using the heat gun to remove the front glass.
Thank you for the answer! :)
by
Add a comment
Add your answer
robbitara will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 111
