No backlight, can see desktop or images on screen!
Hello Guys,
i have a 2008 MacBook Pro Unibody Model 1286A.
Issue: No Backlight, the desktop images can be seen when shining a flashlight through logo
Things done so far:
1-Replaced LCD screen
2-Reset SMC, PRAM
3-Reseated RAM, tested RAM for function.
4-Have video and backlight on external monitor
5-Swapped out Logic board for used one; still no backlight
- Logic board was supposed to be working
6-Swapped out for another logic board; no backlight again
- Logic board again supposed to be good, but this one was used on machine that had an inverter. mine has no inverter.
Notes; All other functions with Second logic board are Ok.
Any help would be appreciated.
2 Comments
MacBook Pro 15" 2.4 GHz Core 2 Duo (Unibody)
by Dan
Roger DeCicco ,"6-Swapped out for another logic board; no backlight again
- Logic board again supposed to be good, but this one was used on machine that had an inverter. mine has no inverter." can't use it with a LED backlit LCD panel. What is your current logic board? Check the 820-XXXX number. Also, what LCD panel are you using. Give us the make/model number.
by oldturkey03
