The EOS 5D is a 12.8-megapixel digital single-lens reflex (DSLR) camera body produced by Canon. Released Q4 2005.
16 Questions View all
Flash will not pop up
The flash no longer pops up, when it should.
Add a comment
Most Helpful Answer
5D doesn't have a built flash.
Score 1
Add a comment
Adjust the hotshoe. Loosen it off and check the contact in the middle, as is sometimes stays depressed/gets caught when you remove the external flash. The camera thinks it has a flash attached and prevents the pop-up flash from coming up.
Add a comment
The 5d doesn't have a built in flash. You need to fit an external flash!
Add a comment
Hi Sally,
The Canon 5D is a full frame DSLR camera and has no built-in flash. So, I am assuming you are talking about an external flash (like a Canon Speedlite) which you attach to the hot shoe of the camera.
Tell us more about the flash (brand, type, etc.) and what settings you used when the issue occurred.
Add a comment
i think u have to get a external camera for this device
Add a comment
Eos 5 film had a pop up, but not the 5D
Update (09/11/2022)
My Eos 500d has a pop up... Are you confusing the 5d
with the 500d??
1 Comment:
with the 500d??
by
Add a comment
Add your answer
Sally will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 779
