Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
iPhone 4 does not power
Hello,
I currently have an iPhone 5S, but I also have an older iPhone 4 from Verizon. It's been a while now since I had the iPhone 4 working. The phone was dying at that time and it needed a charge but at that time I did not have a good charger meaning a charger you know it would be bad because it would go on and off making those charging noises and the next thing you know there is honestly no life to the phone. There is not a sign of the red battery indicator. It will not even recognize in iTunes. It will not even enter DFU nor recovery. As of now I do have a charger and it does charge my iPod Classic, and with this charger it will not charge the iPhone 4. May I please ask two questions? 1.) what could be the problem? And 2.) could it be fixed? Thank you!
Score -1
Add a comment
1 Answer
Chosen Solution
First things first , Replace the battery and see if this solves the issue as apple phone are not designed to run off the charger power alone it first charges the battery which then powers the components. so if your battery has failed this would explain your problem. If not then more troubleshooting can be done once this is confirmed.
7 Comments:
Thank you so much for your help and for your fast reply! :)
by
Hello,
I did not replace the battery yet, but assuming replacing the battery does not fix it than what would be my next part of troubleshooting?
by
Replace the dock connector
by
Awesome! Thank you so much!
by
Alright, I bought a battery and it had 17% charge on it and the phone died and when connecting it and it shows the red charging with the sign of connecting it to the charger and I tried different chargers and all chargers I tried are good.
by
Show 2 more comments
Add a comment
Add your answer
Derek Santamassino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 103
