Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2233 Questions View all
Where to purchase micro tips for Weller soldering iron
HI, I have a weller soldering iron - WLC100
and my tips are too big, where can I get a micro tip for this iron and solder so I can work on he iphone 4s logic board.
I have the ST7 tip which is supposed to be .012 inch thick but it is giant, as well as the solder.
Where can I can smaller solder and tiny tip.
Thanks
Lit
Score -1
Add a comment
Chosen Solution
The problem you are hitting is the limits of most soldering irons. They are just too massive given the size of some of the SMT components used in iPhones & iPads.
This is were a different approach is used. Instead of using solder wire we use Solder Paste and using a Hot Air Rework Station instead of an iron.
Score 1
Add a comment
lit, the ST7 is the smallest tip for your Weller. You may have to look into getting a different station.
Add a comment
Add your answer
pcgeek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 602
