Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
510 Questions View all
Nokia 208 Screen doesn't turn on
so the other day I dropped my Nokia 208 now the screen doesn't work, the phone turns on, I can make calls that's all I can do without seeing what I'm doing, the only thing wrong with the phone is that the screen doesn't turn on. does anyone know how to fix this?
Score 2
Add a comment
1 Answer
Could possibly be a loose connection . if this is the case you will have to take it apart to check the connection. If everything seems fine then your LCD is damaged and will need to be replaced. If there are breaks in the lcd you can see it under bright light. Dark spots , lines or discoloration.
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 896
