The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1423 Questions View all
Missing what I think is a Resistor but not sure exactly.
Ok so I have a water damaged IPhone 5c . I disassembled and cleaned with 99% alcohol but still nothing so i proceeded to remove the Metal shields where i found more corrosion which i cleaned with a brush and alcohol .
After cleaning i reassembled with a new battery . The phone shows no signs of life other than the board gets hot enough to burn in this area SHOWN IN BLACK .
Now i noticed that what looks like a resistor but is probably not was covered in corrosion and looked damaged and seemed to be the source of the heat. would burn finger when touched. So i successfully desoldered it and no more heat but still no life in the phone. I'm looking to find out what this part is called so i can get a replacement to see if it solves the issue.
Part shown in black
These images were taken from ifixit i just highlighted the part i am referring to.
Thank you in advanced.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
st3v3w, that is reference designator L11 which is a 2.2UH-20%-1.7A-200MOHM inductor (coil). It is listed as a TFA201610G which is manufactured by TDK
Score 1
Comments:
Thank you oldturkey03 your knowledge is greatly appreciated.
by
Sorry to bother you again but i have been looking for this part but seem to be having trouble find it . do you have any recommendations as to where i could find it?
by
Where in the world are you located?
by
Canada , New Brunswick .
by
Lets see if we can find the right component. If you can, measure the components physical size. That way we could find an equivalent package size. I'd try to check Murata's LQM2HPN2R2MGH and see if the dimensions would be workable. You doing okay with all the snow and bad weather?
by
Show 4 more comments
Add a comment
Add your answer
st3v3w will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
