Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Why does my replacement battery not boot with power button?
I replaced my 3GS battery with the part from ifixit. It only boots when the power plug is plugged in. When it finally booted from the power plug, it crashed and booted in safe mode. The power/sleep button still works because I can use it to turn the phone off it is plugged in.
Score -1
Add a comment
1 Answer
Chosen Solution
Took the battery back out and saw that one of the small metal cables had come free of the solder pad. Soldered it back together and good to go. I'm taking this as a sign that the iPhone will boot without a working battery if it is plugged in.
Add a comment
Add your answer
sullivanrp84 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,347
