Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Screen won't turn on after glass replacement
I recently replaced the glass on my wife's iPad and after I got it on the screen stopped turning on though I know it still works as a alarm went off after I attempted to turn it back on
Score -1
Add a comment
If the iPad wasn't properly powered off during the screen replacement, the backlight for the LCD may have been blown. Have a close look at the display and check for a dim image,otherwise it is possible that the LCD connector was not properly reconnected.
Add a comment
As brian said, you may have turned it on by accident.
Try giving a hard reset. That should (hopefully) fix it pretty easy
Add a comment
Add your answer
Ali Pittman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 144
