Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
white MacBook won't come out of sleep /hibernate
In last 2 weeks I was able to turn it on twice by just pressing the power button my last session was still in memory. browser was up
battery is fully charged, ac adapter plugged in.. i can hear the humming but nothing on screen and keyboard doesn't work. white light is solid. I have done all kinds of resets. Last time It came back on i changed the power setting to never to stop either hard drive or display but still it went back in sleep mode and pressing power buton does nothing. here is few lines from log i collected last time it decided to wake up.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Contrast.monitorPanel/Contents/MacOS/Contrast and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Geometry.monitorPanel/Contents/MacOS/Geometry and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/VPT.monitorPanel/Contents/MacOS/VPT and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Bezel.monitorPanel/Contents/MacOS/Bezel and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/ExtendedTouchSwitch.monitorPanel/Contents/MacOS/ExtendedTouchSwitch and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/PowerMode.monitorPanel/Contents/MacOS/PowerMode and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization.
Jun 18 13:53:03 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: objc318: Class O3Panel is implemented in both /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/Authorization.monitorPanel/Contents/MacOS/Authorization and /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/TVOptions.monitorPanel/Contents/MacOS/TVOptions. Using implementation from /System/Library/MonitorPanels/AppleDisplay.monitorPanels/Contents/Resources/TVOptions.monitorPanel/Contents/MacOS/TVOptions.
Jun 18 13:53:17 arifs-MacBook 0x0-0x1e01e.com.apple.systempreferences318: Can't access "efi-boot-device" NVRAM variable
Jun 18 13:53:31: --- last message repeated 3 times ---
Jun 18 13:53:31 arifs-MacBook configd35: arp_client_transmit(en0) failed, Network is down (50)
Jun 18 13:53:31 arifs-MacBook configd35: bootp_session_transmit: bpf_write(en0) failed: Network is down (50)
Jun 18 13:53:31 arifs-MacBook configd35: DHCP en0: INIT transmit failed
Jun 18 13:53:31 arifs-MacBook configd35: DHCP en0: ARP detect ROUTER failed, arp_client_transmit(en0) failed, Network is down (50)
Score 1
Add a comment
Most Helpful Answer
You can also reset your power management. Remove the battery and unplug the charger. Then hold down the power button for 5 to 10 seconds. This resets power information and might be related to your sleep issue.
It is also possible that you have a bad battery/sleep cable assembly. This would give these symptoms as well.
Score 2
Add a comment
Try resetting the PRAM (this resets the power management part of any Mac). turn off the computer, press the power button and as soon as you hear the startup noise press and hold Command + Option + P + R. The computer should turn on, light up and then turn off, KEEP HOLDING the keys until you hear the startup sound for the SECOND time. =)
Score 1
Add a comment
Something has interrupted the MacBook in sleep mode. To fix this, press and hold the power button until the sleep light turns off then boot the MacBook up again.
Add a comment
Add your answer
higharif will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 3,392
