Exactly RAM spec for buy : ecc? 184pin ok or 200pin better/needed?
Hello,
I would like to change the ram but i didn't get some specs needed.
Does the "NON ECC" RAM is correct ?
Does 184PIN CAN WORK INSTEAD OF THE 200PIN SELL ON IFIXIT ?
.. Or maybe 200pin RAM will work better ?
DOES 333MHZ IS EXACT RAM FREQUENCIES REQUIRED ?
.. Or this specs is not too look ?
Will old linux recognize this new ram ?
.. Or there is no link to os with changing ram
Score -1
1 Comment
Here's the spec sheet from EveryMac on your system: iBook G4 1.42 GHz (Mid-2005)
by
Add a comment
1 Answer
Chosen Solution
From EveryMac: PC2700 DDR SDRAM 333 MHz
"The maximum memory capacity of this system is 1.5 GB with 512 MB onboard and a 1.0 GB SO-DIMM."
You can't force fit any memory module (physically or what it runs at). Sadly, these modules are difficult to get as they are no longer being made.
Score 2
Add a comment
Add your answer
Wassup Rocker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 106
