Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
No service after taking apart.
I took my iPhone apart to replace the vibrator and i then got confident and readjusted the power button becuase it wasnt right, i then couldnt get it working forever but finally got it and now i get HORRIBLE service. before where i got 5 bars and 3g im barley getting 1 bar and E. i dont know what it could be. my only guess is the number 7 connector because it doesnt seem to hook up right. any help would be awesome. everything els works fine thou just bad service. Thank you all in advance,
Score -1
Add a comment
Chosen Solution
your right - if no. 7 isn't connected well, the reception could be bad - but it's a fragile part - be careful not to break the connector!
try to connect it properly (i know that sounds not "nice" - but i would do that for you if you bring it, but in my case - i'm from germany and that would be a to long distance for the most ifixit users ;-) )
4 Comments:
ok the problem is the numer 7 doesnt seem to connect right, it wont snap on there at all. i think it might possibly be broken. is there anyway i can fix that or do i have to get new parts? thanks for all your help
by
that depends where it's broken - cable side or logic board side? - but if it's broken, it should look "odd"
by
I think both sides are messed up, it wont snap together but i tried holding them together hopeing that it would show some reception but it didnt do anything.
by
if one of the sides has lost it's contact - you won't have any signal. i did only find the antenna on ebay,changing the part on the logicboard would involve soldering (but in that case, some "guerilla's" simply using 2 small wires and soldering the dock antenna contacts to the opposite side on the antenna, the cables should be long enough to open the phone again and work "freely" with it - but thin enough to get hidden inside the phone
by
Add a comment
yeah i have the same problem but i can snap my number 7 in place but i still get one bar some times 3 but thats only at my house if i go any were els i get noting
Add a comment
Add your answer
brandon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,163
