Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
What causes the screen to become unresponsive?
After briefly placing my iPhone in my pocket, the screen became dark (except for top info band). When I tried to shut it down it will not respond to a swipe to continue shutting down....what is up??
Score -1
Add a comment
1 Answer
Chosen Solution
Is the screen totally unresponsive ?
if so, try to reset the iPhone (press and hold the home button and the sleep button at the same time until the iPhone restarts (should take not longer than 10 seconds)
if it's "only" the top area - the digitizer is most likely defective.
since the phone isn't to old and should still be covered by warranty - i would go to apple and let them fix it.
if you voided the warranty - you would most likely have to repair it on your own.
you would need the front panel kit wich includes the front screen and the needed tools.
use the front panel guide for that operation
Score 1
Add a comment
Add your answer
Sara Howard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 849
