1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Questions View all
Replaced top case, keyboard still has non-working keys
Replaced the entire top case after a Coke Zero spill caused parts of the right side of the keyboard to quit working. Now, I still have a stripe of keys (8,9, U, I, K, L, ;) not working, and the power button doesn't seem to want to turn the system on consistently.
Should I be looking at replacing the trackpad, or is it more likely the logic board took damage I haven't found. It looks clean and there were no signs liquid had penetrated beyond the keyboard.
Add a comment
1 Answer
Chosen Solution
Usually such a fault is at keyboard level.
Were the same keys from before damaged? If not, and the new keyboard has a different set of faulty keys, then you got yourself a damaged replacement keyboard.
In other words, I'd start by trying to rule out a faulty new keyboard before looking for something else.
Score 3
2 Comments:
It seems to be the same keys as before, although I'm not 100 percent sure because I didn't log all the dead keys before I swapped the cases.
It's my understanding that the keyboard inputs route through the trackpad daughterboard back to the logic board over the same cable as the trackpad input. I hadn't noticed any trackpad problems, so my suspicion was that the keyboard connector was having problems.
by
Examine the trackpad board and all cables with something like 20x magnification (or more if available). Pay special attention to all the connectors and cable tips, and *underneath* anything that can hide water damage.
by
Add a comment
Add your answer
Brian Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 138
