Repair information for printers made by Canon.
427 Questions View all
pf 04 (3630B001AA) print head for canon ipf 750
hi, i have this situation my print head pf 04 (3630B001AA) for canon ipf 750 is no longer working (in the simple mode) when i turn on the plotter it says print head need clenning ...if this message appears again you should replace it !! ok ....for the first time i replaced it ...but the new one after printing the specified quantiti stoped working .after somme diging i find how to acces service mode and hear surprise it works perfectly !!! somme diging and i found a head chip reseter is this the sollution?? i want your advice ?!!
Add a comment
Most Helpful Answer
To access the Service mode just press Paper+Info+Power during the power up. From there do a nozzle check (twice as precise as the user mode test, and the internal software does not compensate for the loss of some nozzles). If you find any line missing of a large portion of the color squares not printing you have some hard ink inside the print head. If it prints OK (that was my case), than the print head is OK, just that the new firmware from Canon is telling you have to pay them from time to time. The print head is "recommended" to be changed annually. You can find a way to decript the Canon programming, or just try to find an older firmware on some forum and downgrade (worked for me). From the service menu you can initialize the counter but in the end the error will show again. I haven't used the head resetter, but that might be a good option (and I'm thinking on buying one too). Good luck!
Score 3
3 Comments:
can you send me the old firmware of ipf750? thanx ..my gmail bousmaha6@gmail.com
by
Can you send me the old firmware of ipf750? Thanks to me I will thank my gmail rosbeldepaz@gmail.com
by
can you send me the old firmware of ipf750? thanx ..my gmail klaiimed@gmail.com
by
Add a comment
Perform hard reset for your printer. Following are main steps for hard reset.For complete setup go to Canon iPF750 Manual.
  • Turn ON the printer.
  • Press and Hold the “Reset button” on the printer.
  • While pressing the “Reset button“, press and hold the “Color Start” button.
  • Wait for 5 seconds.
  • Release the “Color Start” button, and then release the “Reset Button“.
  • Wait until the printer starts to configure itself. ...
Score 1
1 Comment:
which it the RESET BUTTON on ipf 750?
by
Add a comment
Hi! Did you know if this works with oce cs2436?
Add a comment
Add your answer
gamosys will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 146
Past 30 Days: 200
All Time: 7,741
