Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Why can't I use my headphone jack as a line out?
When I plug headphones into my Samsung Galaxy Tab 4 they work normally, but when I try to use the headphone jack as a line out, the internal speakers remain on and nothing goes through the external amp it's plugged into. It seems the Galaxy does not recognize the stereo 3.5mm cable as a need to send the signal out the headphone jack. Any ideas?
Score -1
Add a comment
Most Helpful Answer
Roger, check the male end of the jack. Make sure that it has the same assigned contacts as your headphones. your tip and ring assignments most likely are different. Are you using a 2 ring or 1 ring connector?
Score 2
Add a comment
Have you tested the lead you are plugging in ? Shouldnt be an issue really.
Score 1
Add a comment
Add your answer
Roger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,255
