Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
iPhone is not turning on, even when is plug into the computer
Hi all,
My iPhone suddenly started to heat up when I plugged it into my shuffle base, and then it did not turn on again anymore... So I guess the battery is dead but I am not sure... Anyone have a suggestion of what is going on? Thanks...
Ed
Score 1
1 Comment
ur mother board might be dead
by
Add a comment
Chosen Solution
Thanks.. I will try to do that... I just don't want to waste my time open it and not solving the problem...But thanks.. I appreciate answering me!
Add a comment
Most Helpful Answer
heating up is not good. it might be the battery, but it could also be something different.
i would suggest that you open the phone using the battery guide you will need a multimeter and the tools mentioned in the guide to do that.
measure the battery voltage on the contacts - if the battery has less than 3v - the phone will not work.
i would also check the smaller parts if something looks odd (use the pictures from the guides or the teardown to compare it to)
Score 1
Add a comment
Add your answer
Eduardo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,038
