The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Machine stopping,have to restart.
Avatar
Tony
Answered
4 hours ago
I am having a F 1 code come up and it will not do anything. usually just turn off and try to turn back on. Some times have to turn it back on 3 0r 4 times to get it to work. any suggestions?
1 Comment
I have the same problem only my washer stops constantly throughout the each cycle. I literally have to stand in front of the washer the entire time restarting to wash a load of laundry. And, water is leaking from the washer somehow even when not powered on.
by
Add a comment
Chosen Solution
First, unplug it for 5 minutes to allow it to reset. Next take a look at this answer: Need help with F-01 error
Score 1
Add a comment
If the machine sometimes stops mid cycle check the water outlet hose.
I had this problem the machine was fine most of the time.
The outlet hose went under the cabinet to the waste trap rather than over it.
When water was emptied from the sink it backwashed the hose overfilled the machine and stopped it working.
Some part of the outlet hose should always be higher than the connection into the sink waste trap otherwise when the sink is used there will be overflow onto the machine.
Add a comment
Add your answer
Tony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 969
