A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
How to test my ps4's psu
Hi, I took out my ps4's psu and gave it to a friend. He fixes lcd TVs, and tested it. He told me that the psu doesn't reach the 12v, he said it only reached 4.7v of the standby. He tried it on a lcd and it didn't work. Is it possible that he did something wrong? Is there a special way to test it? Nothing inside the psu suggest to be broken or burnt. I just dont want pay for a new psu if it is working...Thanx!
Score 3
Add a comment
1 Answer
Chosen Solution
It's always possible that something was not tested right, but if your friend knows what he's doing then hopefully he would know how to check these. I'm guessing that your PS4 is turning on then right back off since this is a common problem with them.
I don't know of a special way to test these PSU's. These power supply's are just a switch mode power supply. Anyone with some knowledge and experience of switch mode power supply's should be able to test them.
Normally when these PSU's go bad there is nothing that is burned...there is no way to tell what is wrong by looking at it you just have to test them.
One way to do a quick check is to put the PSU in the PS4 and turn on the PS4. If the blue light barely even blinks on or doesn't go on at all, then you likely have a problem with the power supply. If the blue light comes on for a few seconds and the fan starts to spin up then it turns off then you probable have some other problem.
I hope this helps.
Score 4
3 Comments:
Please my ps4 is saying ‘cannot start ps4 ‘ that I should download the version 4.7 but I already have that
by
@kennedy kinikanwo No way for me to know for sure...could be faulty hard drive or bad solder joints under the APU.
by
Hi there,
Playing days gone on Ps4 pro lately, and most days, I can play for 5 or 6 hours at a time. Last month I cleaned it(no dust), reapplied thermal paste Arctic mx 6, I put new Arctic thermal pads (1mm) and after playing every other day for 2 weeks, my console shutdown, but the fan is whisper quiet. Was pretty hot to the touch also. The fact that the fan didn't kick up, does that sound like the PSU? Could it be the 4 pin cable, connecting PSU-motherboard, (it smells like burnt plastic on one end) but no burn marks on it. Could initializing the console fix this? I don't know how to test the values on the PSU. Any suggestions would be greatly appreciated.
Thank you in advance.
by
Add a comment
Add your answer
Fede will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 46
All Time: 10,800
