Shop the Holiday Gift Guide
A general purpose laptop released in 2010 with a 15.6" screen.
Question Closed
What is error code 0xa000000e.
triing to reset to factory settings with acer recovery dics
1 Comment:
could you post a picture or is this simply a popup Error:0xa000000e.?
by
Add a comment
That is a recovery install failure error.
You may need another copy of your disk.
1 Comment:
I got another set of recovery disks from Acer, still having the same error code show up . I put my own password ln for f-2. how do I return it back to default setting? Maybe that might make a difference
by
Add a comment
I have a acer aspire to and i had the same problem i had corrupted or missing files try running a system scan i use sfc/scannow/f in the command prompt admin that will check your system files and repair broken or missing files also run a antivirus programm that worked for me.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 448
