Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
31 Questions View all
Question Closed
Connection to a sound bar
When connecting the iPod to my sound bar, it stops playing periodically, I have bought a new connection lead but to no effect.
There is definitely something wrong with the inner working of the iPod itself.
can anyone give advise on what to do next .
Add a comment
1 Answer
Chosen Solution
Here's an answer to a similar issue on an iPod Touch, it mostly applies to your device as well:
I'd try to determine where the fault lies first:
1- Try a different iPod or iPhone to check if issue is with cable or iPod.
2- If issue is with the lead, try using a better/genuine product;
3- If issue is with the iPod,
3-A/ If the songs you are trying to play are stored on your iPod: try cleaning the dock connector (where the charging cable plugs in) using a soft toothbrush dipped in 90%+ isopropyl (rubbing) alcohol.
3-B/ If the songs you are trying to play are streamed to your iPod: check that your Wi-Fi connection is fast enough. Or play the songs on your iPod and see if they are running well or they also intermittently stop playing.
Go through the above to start with, and let us know what you find out or if your issue is fixed.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 519
