Repair information and guides for MacBook Pro models with 13" displays.
9751 Questions View all
Question Closed
Why won't my laptop recognize my brand new internal hard drive?
Hello,
Yesterday I put in a brand new WD 1TB internal hard drive for my 2009 Macbook Pro. I followed every instruction carefully, but when I turned on my laptop, it flashes a folder with a question mark. Is it because my new hard drive doesn't have any of my data on it?
1 Comment
I also have Yosemite installation on my usb. It only shows the usb when I hit the option key when the usb is inserted.
by
Add a comment
1 Answer
Chosen Solution
Your new drive has not been formatted for MAC. Try hooking up a ethernet connection to the internet and hold down the R key while starting up to see if it will connect to Apple and get you to Disk Utilities. Or startup from your original system installation DVD, go to Disk Utilities and format the drive then install a system. Then you can do upgrades. If your old drive failed I would highly recommend replacing the Hard Drive/ IR cable as these are know to destroy hard drives.
Score 3
1 Comment:
Thanks so much for your reply! I didn't think anyone would answer. And thanks very much for your suggestion! I will definitely try that! I will let you know the results later on!
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 390
