Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Is there any correlation between logic boards and youtube downloads
I was just reading your website and one member had a raised a question on replacement of logic boards by APPLE and the editorial board had asked question what do you do whether you do streaming and You Tube editing is there any correlation? I ask because I do a lot of downloading TV broadcast through AVER TV VOLAR hub.
I use a cooling pad since the exhaust fans operate at the maximum speed. After downloading, I burn it in a DVD. What safeguards should we take to avoid these expensive repairs.
Is the system designed to be in use for continuous 12 hours, I'm from INDIA and the ambient temperatures are quite high and we cannot afford to change the system frequently.
Please explain.
Thank you
NARAYANA LAKSHMANAN INDIA
3 Comments
Please supply the last four digits of your serial number so we can correctly identify which model you have.
by
Last serial number F66D
by
Add a comment
1 Answer
Chosen Solution
I think you need to review your usage a bit here. Downloading files (any) can push your systems temp & fans quite hard. You could try using an external HD to hold your downloads as you download them as well as CD/DVD burner to lessen the heat buildup within your system as a start.
You should also think about using your system in a cooler environment if you can. Try the night or a room with AC. While that may not be possible you may need to lessen the amount of downloading you do during the heat of the day.
Download a good temperature & fan monitoring app. I like this one: Temperature Gauge Pro. Review the temp modeling they have for your system (you'll need the full version). So you can monitor things better.
You may need to do some cleaning of dust buildup internally and refresh the thermal paste on the CPU/GPU heat sink. Given the area you live in if its dusty this may need to be done more often.
As you didn't give us an exact model I can't offer you much more here.
Update
If you believe your system is running hot without any heavy loading as I suggested, you should open up your system and clean out the dust buildup. Use a soft paint brush to scrub the surfaces and can'ed air to blow away the debris. Don't spin up the fan with the can'ed air as you can damage it. And lastly, don't snag any of the components in the process.
You can follow also this IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement to take the logic board out to refresh the thermal paste. I strongly recommend you use a good quality paste like: Arctic Silver Thermal Paste and use this cleaner to clean the old paste fully off: Arctic Silver ArctiClean as many of these pastes are hard to clean off. Follow this technique guide on how to effectively put down the new paste: Technique: Applying Thermal Paste.
Arctic Silver ArctiClean Image
Product
$9.99
Electronics Skills Image
Guide
How to Apply Thermal Paste
Difficulty:
Moderate
5 - 20 minutes
MacBook Pro 13" Unibody Mid 2009 Logic Board Image
Guide
Difficulty:
Difficult
40 minutes - 2 hours
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 77
