The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Questions View all
Question Closed
Computer recognizes drive but I can't erase or initialize
Hello, I recently purchased a 3 TB Toshiba internal hard drive that I want to use as a second drive in my Duel Mac 2Ghz PowerPC G5. The computer recognizes the drive but I cannot erase or initialize the drive. I'm running Mac OS 10.4.11. Any help would be great, thanks!
Tym
Add a comment
1 Answer
Chosen Solution
More than likely you are having a SATA problem. The HD you recently purchased may promise to be backward compatible or automagically self limiting (and should be) but I belive it's not working.
Your ID fits 5 different versions of the G5 box, but all use SATA I HD's.
You may be able to manually set the SATA speed of the drive. If not you may want to try a different SATA cable or need to find a different drive.
If this answer is acceptable please remember to return and mark it accepted.
Score 2
1 Comment:
I think the problem is my computer uses ATA, not SATA, for the internal hard drives.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 121
