Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Microphone not working when speaker is on!
Hi All,
After changing the screen of my iphone 4s, everything is working except when I use the microphone when the speaker is on.
I think i've a bad contact because i heard some noisy sound.
Do i have to check cable ?
Do i have to change a piece ? which one ?
Thanks for your help
Benoit
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi Benoit, Yes sir it looks like your going to need to change a cable. If the microphone is not working when speaker is on, then check for damage to volume headphone jack flex.This flex cable also has a microphone attached to it. This cable is probably damaged and needs to be replaced.
Heres a link to the guide to replacing that flex cable:Here
& Heres the part link so you can buy the part.
Hope this works for you my friend!
Good Luck!
Score 1
Add a comment
Add your answer
Benoit will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 12
All Time: 148
