Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
How can I fix my Laptop Screen from wobbling?
The Black hinge cover is damaged and when i touch my screen to move it to a different position it wobbles back to the original.
It is not under warranty and I'm looking to do it myself if possible.
Score 2
3 Comments
What are the last 4 figures of your serial number?
by
The last 4 are DTY4.
by
Apple MacBook Pro "Core i7" 2.9 13" Mid-2012 Specs
Identifiers: Mid-2012 13" - MD102LL/A - MacBookPro9,2 - A1278 - 2554*
by
Add a comment
Chosen Solution
Go through this guide and look especially at step #13. MacBook Pro 13" Unibody Mid 2012 Display Replacement
There are 3 screws on each hinge that you need to check and possibly tighten.
Score 3
2 Comments:
Thank you I'll try it out. I start from the beginning i presume?
by
No, just open it up and go straight to the screws. Be careful that the screen is aligned before you lock it place. Do one screw at at time, then check it. Check to see if any are loose, do one on the right then one one the left checking to see if it closes correctly. The first two you tighten will probably lock it down.
by
Add a comment
I found this online and it may help resolve your issue
https://www.youtube.com/watch?v=D8BixdIB...
Score 1
1 Comment:
Thank you for your effort ,but my mackbook pro model doesn't look like beneath the casing.
by
Add a comment
Add your answer
Ali will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 14,833
