The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Question Closed
water damage galaxy s3 help me please!
i have a galaxy s3 that has been water damaged for a good 2-3 months , but one day i decide to take a look at it and the fone turned on just fine only for a few min , so i took the fone apart put rubbing alcohol and when that was done , it didnt turn on but when i put the battery to freeze and try to put it back in the fone it turns on for a few more min.. do you have any solution on how to solve this ? everything on the fone works well .. it turns on and everything but the screen remains black they keys light up just fine
Add a comment
1 Answer
What type of alcohol did you use to clean the motherboard? The correct type should be Isopropyl .Best to sink it in Isopropyl for 5m then use an air compressor to blow in every corner of the motherboard make sure all the Isopropyl is clean out.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 85
