Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
309 Questions View all
WIll 2012 MBA motherboard fit into 2011 MBA's housing?
I need to replace my MacBook Air's motherboard (2011, 13' inch) now that I have the chance I was thinking of buying a 2012 MBA's motherboard, as it is better in a number of ways. Will that be possible?
Thanks
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Generally you can not cross model years swapping logic boards (and may other parts). That rule holds true in this case. Use the "compatibility" link on the top right of the page.
If this answer is acceptable please remember to return and mark it accepted.
MacBook Air 13" (Mid 2012) 1.8 GHz Logic Board Image
Product
$299.99
Score 1
Comments:
Have you actually tried this though? To me, it looks like the 2012 board has the same connectors in the same locations as the 2012. Just saying that it may not be *intended* to be compatible, but it might be anyway...
by
Nope didn't try to - 'cuz I can read a parts catalog. If the board would fit other years the catalog would list them If you find out otherwise then by all means come post
by
Add a comment
Add your answer
Kex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 459
