Where is the airport connecter on the logic board?
I opend the lower case to clean the fan today,and when i turned it back on, it said no airport card, i think i may have accidently dissocnected it.
Check the connectors and the card connectors on the logicboard. If it's loose, reconnect it. If that doesn't work, replace the WiFi card or the WiFi card fuse. You may even have to replace both. You can see these guides on how to do the repair here.
I dont know what connecter it is, and it shouldn't be bad because i used it for most of today
They are on the airport card. maybe one came loose
The airport now works sometimes, i didn't open the compputer back up even, but now it isn't working... is the airport card on the keyboard side of the logic board or the under side/.
Now check how well it is in the slot and if the card is REAL secure it is failing
Where is the airport carD?
The Airport card on this model sits in the base of the display, next to its antenna. It is connected to the logic board via the LVDS cable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,121
